The rough cold start and rough running cold has not much to do with mileage, or tons of fuel dumped in to the cylinder, or the piston rings.
It is a beginning of injector related issues, and usually the latest PCM/FICM flash at the dealer takes care of it. It's called heat flash, and since your truck is an 06 and you probably under 100k miles, it should be covered under warranty.
