Ford Concepts & Rumors Heard you heard? Have you seen? No? Come on in.
powerstrokes to cummins?
Old May 10, 2006 | 11:57 PM
ford4ever's Avatar
Default powerstrokes to cummins?
I am not sure wether or not this is true but I have heard that ford is going to put cimmins in the superduties in the next couple of years. The powerstrokes are going to be 6.4L dual tubro and then the cummins will go all to ford after the powerstorkes attempt to fix its problems. What does that mean for dodge well I have also heard that they will go to mitzubishi diesel engines if that is spelled right. If all this is true say good bye to dodges truck line for a while because the cummins has a pretty strong following and their half tons are garbage ( I know I had an 05 hemi for six months and I had it in the shop 7 times). If anyone knows anything about this I would like to hear it.
Old May 19, 2006 | 03:58 PM
toyota4by's Avatar
Default RE: powerstrokes to cummins?
well as of 2007 high tech deisel number 3 will come out. this will revolutionize diesel performance. this new fuel will burn cleaner then gasoline but it may have effects on pre 2007 deisels. the effects might be fuel seals going bad, the fuel is still in testing but look it up under deisel muber 3
ford4ever
Oct 3, 2007 08:49 AM
investor
Sep 17, 2006 03:06 AM
bigdodge22
Jun 28, 2006 03:05 AM
Yicco
Apr 19, 2006 09:34 PM
bigdodge22
Feb 28, 2006 05:56 PM
