Old 09-29-2009, 09:26 PM
noslocars noslocars is offline
Default 1999 5.3 Stalls when Cold
Hello Everyone,
I have a question hopefully someone can answer. I have a 99 Chevy Silverado extended cab 4X4 with a 5.3 Liter. I am having trouble with it bogging down and almost stalling just after I start it and only when the temperature is 40 degrees or colder outside. Once it is warmed up it purrs like a kitten. I don't have a check engine light. I have replaced the TPS, the CTS, the fuel filter, Cleaned the Mass airflow sensor, had the injectors cleaned twice. Once by a local shop and then again by the dealer who was trying to troubleshoot the same problem. I told them I had them cleaned but they said they had the ability to do it better. The dealer also updated the computer. I still have the same issue and was hoping someone might have an answer. Thanks in advance.
Old 09-30-2009, 02:22 AM
RUFFNECK4LYFE RUFFNECK4LYFE is offline
Could be the IAC(idle air control) valve. Its what controls the idle during warm up, engine loads, electrical loads. But it would do it almost all the time so Im thinking maybe check the FPR(fuel pressure regulator), vacum leaks like the small hoses around the intake.
That way you'll Learn!!!!
Old 09-30-2009, 07:40 AM
Mr_Shamrock's Avatar
Mr_Shamrock Mr_Shamrock is online now
Super Moderator
I just sold Yukon that was doing that and it was the throttle body. It was really dirty inside. A can of throttle body cleaner and about 10 minutes time and it was smooth again.
Welcome to the dark side of the moon!
2002 GMC Sierra 1500HD 6.0 2WD - Black Bear Tune, Flowmaster 70 Series, & Custom Air Box
Old 11-06-2009, 06:31 PM
Well, I finally got it fixed. Let me tell you the process. I changed the TPS, CTS, Cleaned the fuel injection system twice, I changed the intake gaskets and the fuel pressure regulator and after all that I still had the problem. I tested it and had 30 PSI fuel pressure only when it was cold. I finally broke down and replaced the fuel pump and all is well now. It feels like I have more power now and it runs great. I have never had a fuel pump act this way. Usually they hard fail and just die. Anyways I am happy as a clam now that I got my truck back to normal.
Old 11-11-2009, 01:09 PM
sooriugh73's Avatar
sooriugh73 sooriugh73 is offline
Send a message via ICQ to sooriugh73
Default 1999 5 3 Stalls when Cold
Ok...Sorry if I posted this in the wrong area, but Im a Newbie with a quick question. Heres the problem When I first start the car in the morning it is very hard to start....Rough Idle/Stalling etc. If I give it gas when starting and keep the RPMs above 2K I can keep it running. This only happens on the first start of the day. Even if its been sitting all day at work, it will start right up. Problem only happens if sitting for 12 hours or more and the weather is a bit cold....There is no other performance problems....Once I get it past the starting/idling problem it runs great.....Any ideas of what is causing this problem???
Old 11-11-2009, 04:37 PM
Yours really sounds like the IAC Valve. When it warms up, turn your AC on at idle and see if the RPM's drop and stay down or surge a little.
Old 11-12-2009, 07:10 PM
It sounds like its your fuel pressure regulator, and or your fuel pump. When your truck sits the fuel pressure regulator could be leaking fuel into your intake therefore making it hard to start. When it is cold check your fuel pressure with a test gauge and see what it is. It should be around 70 PSI or more. If it is not its most likely your fuel pump.
2000, 2002, 53, chevy, cold, ford, fpr, fuel, idle, pressure, ranger, regulator, rough, silverado, stall, stalling, surging, tundra
