Toyota Tundra Discuss the Toyota Tundra here.
Wheel Cylinder problem
Old Sep 10, 2006 | 01:27 AM
discoinferno65's Avatar
Default Wheel Cylinder problem
so i just bought a 1971 Toyota HiLux recently and as i was bleeding the brakes i realized that the wheel cylinders were all bad. One had even busted open when i pressed on the brake shooting oil all over my friend. I do not have the 200+ dollars to replace all 8 wheel cylinders (i know atleast 3 are bad i haven't even checked the back yet tho i'm just assuming). Unless someone knows where to get some wheel cylinders for a truck that old for anything under 15 dollars, i think i'll just stick with getting a rebuild kit. My only concern in the re-build kits is how long will the cylinders last if i rebuild them all?
Old Oct 12, 2006 | 04:52 AM
toyota4by's Avatar
Default RE: Wheel Cylinder problem
well you can always check your local wrecking yard. Heres a tip, if you find what your lokking for, when you got to pay for it say "man, i cant beleive that napa wanted 25 dollars for this stupid little part." when really the part was 75 or what ever, the guy at the wrecking yard goes, "yeah they try to rip you off" when your geting the deal. they try to over chage you, so dont let them.
Evan Housewright
Feb 6, 2011 03:47 PM
piton
May 13, 2008 07:00 AM
ob22005
8
Mar 4, 2008 03:22 AM
rustyfan
Feb 17, 2008 03:33 PM
superddd
Jun 12, 2007 09:33 PM
