Dodge Dakota Forum Discuss the Dodge Dakota here.
Bad Ground
Old Sep 29, 2006 | 09:35 PM
clyons's Avatar
Default Bad Ground
Two days ago I made a post about a brake light problem. After further inspection I found that with the headlight on and the brake pedal pressed all of the elements in both bulbs barely light up. I am fairly sure I have a ground problem. Does anyone know where to start looking? Thanks
Old May 10, 2008 | 11:44 AM
vernjeggies's Avatar
Default RE: Bad Ground
i had a similar problem with my 91 s10... it turns out there was a broken ground wire attached to the frame rail under the bed of the truck... i ended up buying a complete wiring harness for the back end before i realized the ground wire hanging there. should be somewhere close to the tail lights if its the same problem... worth a look anyway
JJ CHEVY
5
Jan 31, 2012 08:26 PM
zleehw
Mar 9, 2010 12:28 PM
ScottM75407
5
Jan 8, 2010 08:15 AM
gruusome
May 24, 2006 12:55 AM
mtrailfan
Feb 1, 2006 01:17 AM
