Bleeding Power Steering Fluid
Old Jul 6, 2005 | 11:06 PM
pewter_gashog's Avatar
Default Bleeding Power Steering Fluid
I have replaced the idler arm, pittman arm and steering box on my 02 2500HD. Is there a recommended procedure to bleed the pump or box? Thanks in advance.
Tom
Old Nov 16, 2006 | 04:49 AM
makoltd's Avatar
Default RE: Bleeding Power Steering Fluid
There is just one way to bleed the Power Steering Box and it is simple. I pumped all the fluid from my pump w/handheld pump, ran GUNK Power steering oil through system, pumped it back out and topped it off with GUNK "Clear," PW Steering fluid (Not cheap, not junk, and has the longest life). To Bleed the Power Steering unit you just need to do the following
1.) Fill to cold level (truck needs to have sat for 1 hr)
2.) Start Truck
3.) Turn Steering wheel left to right NEVER hitting end bump stop; meaning, don't take it all the way where you would hear the pump hissing, 3 turns each way from center should do it.
Let truck run for 5 mins which will take it from Cold to Hot
4.) Top off PW Steering reservoir to Hot Level.
That's it my friend. You've bleed the system
Hope that helps
GL
Grteek
longdistance
May 20, 2010 08:12 AM
Charle7
Jun 1, 2009 08:14 AM
bctarver4
Nov 16, 2008 11:24 AM
IndigoBlue04
Mar 31, 2008 01:02 PM
Ramrod56
Oct 5, 2006 09:25 PM
