ABS Question
Old Dec 1, 2007 | 04:16 PM
dave1125's Avatar
Default ABS Question
I have a 00 Silverado. When stopping at low speeds the ABS kicks on. I know this is a problem with either a bad or dirty sensor. I have also read that you can pull the ABS fuse to eliminate this until it is fixed. If you pull the fuse will the brake light come on and stay on until it is fixed? Currently the brake light is not on.
Thanks
Old Dec 2, 2007 | 05:03 PM
stopspazinout's Avatar
Default RE: ABS Question
i would imagine it does not turn the light on seeing as it kicks on if the brakes are active or there is a problem in the system. argon would be able to tell you for sure.
Old Dec 2, 2007 | 06:43 PM
Argon's Avatar
yes,you'll get 2 brake lites on
alan7407
Sep 3, 2011 10:07 AM
GMCSierraFan
Apr 25, 2011 04:38 PM
willbjew
Aug 19, 2009 01:36 PM
BLK02
Feb 26, 2009 04:52 PM
jds313
Oct 17, 2005 02:22 PM
