General Motors Tech Chevy tech talk within.
94 sierra loads up when i let off gas
Old Jul 18, 2008 | 04:59 PM
maddog427's Avatar
Default 94 sierra loads up when i let off gas
i have a problem with my 5.7 in my 94 sierra loading up when i let off gas. i rebuilt throttle body, new injectors new sensors, new gaskets. also did a tune up and replaced o2 sensor in pipe past header. still loading up, any thoughts???
Old Aug 14, 2008 | 09:24 PM
BigAgitator's Avatar
Default RE: 94 sierra loads up when i let off gas
I'm having the same problem with a sierra that i'm working on!
it runs well for a few minutes and once it has run for about 10 minutes at idle, it wants to stall. All of a sudden the mixture gets way way too rich.
No bad codes have come up and the "throttle body has been swapped as well as the computer" according to the guy who worked on it before me. I can't be sure how much of this stuff is accurate about swapping parts out.
Compression is good and it doesn't overheat.
I was going to start with O2 sensor and throttle position sensor then move to MAPP sensor and so forth.
Any suggestions would be great and I hope you can get your problem resolved. It sounds like we have similar problems.
Thanks
~Tator
Old Aug 19, 2008 | 05:54 PM
For anyone reading this-
I was able to fix my problem by replacing the coolant temperature sensor on the front of the intake manifold. it was $29 at Napa.
Hope this helps.
Tator
early93
Jan 6, 2013 06:31 PM
acrtech
12
Mar 13, 2010 03:16 PM
j_remington
11
Jun 12, 2008 08:27 PM
Kozrado93
Oct 21, 2006 08:41 AM
GMCSierraVortecHP2K5
May 26, 2006 02:04 AM
