Ford General Tech Ford tech talk within.
What transfer case models has Ford used?
Old Aug 12, 2008 | 10:20 PM
Kahn Strictor's Avatar
Default What transfer case models has Ford used?
What transfer case models has Ford used? Were any of them factory equipped with a slip yolk eliminator? Thanks everyone!
Wm
Old Sep 26, 2008 | 01:24 AM
duelle's Avatar
Default RE: What transfer case models has Ford used?
two that I know of early models72 to 78 NP205 t-case all gear driven came divorced in f250. super strong case. fix spicer yokes. 80 to 95 broncos & f150 used borg warner 1350 t-case fix flat 4 bolt flanges. 5.8L engines only. 5.0 used 207 slip yoke. the 1350cse comes ether manual shift or electic motor shift? if your in california call anahiem gear in city ofAnahiem they have what you need. if you speak to patt tell him alex from 4WP told you to call..hope this help you..
Old Sep 29, 2008 | 05:31 PM
Excellent info man, thanks a bunch....that beats the hell out of crawling around in a junkyard all day of which I'd probably still not found the answer to my question! I've been looking for common boneyard parts that can be used to build slip yolk eliminators or vehicles that came with them stock that can be used on the NP231 and NP242 transfer cases. I'd also like to find a beefier boneyard upgrade to the NP231 and NP242 TCs....anyone have suggestions?
Wm
Macauboy
Apr 18, 2014 01:36 PM
cubpak89
Jun 20, 2013 11:06 PM
cubpak89
Sep 8, 2011 07:39 PM
SWOHSnow
Dec 11, 2009 11:05 AM
Kahn Strictor
Aug 12, 2008 10:22 PM
