General Motors Tech Chevy tech talk within.
Ground wire burning in to..
Old Mar 14, 2006 | 08:32 PM
gruusome's Avatar
Default Ground wire burning in to..
I have a 1980 Chevy 4x4 truck. When I try and start it up it keeps burning the ground wire in to. The ground wire I'm talking about is the one that goes from the frame to the engine block. Any help at all would be gr8.
Thanks
Old Apr 2, 2006 | 02:25 PM
71 chevy 4x4's Avatar
Default RE: Ground wire burning in to..
sounds to me like you don't have a good battery to engine block ground.Your ground cable from the battery should go directly from the batt. to the engine.than smaller wires are used to ground engine to frame and body. If it is on the body or the frame, when you try to start it the high amps that the starter draws is too much for the smaller gauge wire used to ground the frame to engine and therefore fries the cable.relocate your main ground cable or if it is on the engine already make sure the connections are clean and tight.
Old May 24, 2006 | 12:55 AM
DominicZ71's Avatar
Its not against the exhaust manifold is it?
cubpak89
Aug 6, 2011 04:25 PM
bigchevy
13
Aug 17, 2009 02:56 PM
rxsteven
Apr 4, 2008 09:21 AM
87 F350 banks
Sep 6, 2007 07:35 PM
impaladakid
10
Aug 25, 2007 10:34 AM
