  #11
Old 04-14-2009, 04:39 PM
6mins2live's Avatar
6mins2live 6mins2live is offline
88-89 hood release. You have to hit it just to the left of the latch on the front of the hood and it will pop right up every time. I know lots of people who have had this problem and it always works.
88-98 Intake manifold gaskets. Always seem to go if you use dex-cool coolent. Not a major problem, but you will be leaking coolent and you will def smell it.
1994 Z-71 - 3" lift, Flowmaster 50 duals, 33" BFG ATs, Dual 4' whips, 3.73 Posi Rear, Remote Start, Powder Coated Nerf Bars, Rancho RS 5000 Shocks, Billet Grill, Headers and Flowmaster 40 True Duals coming soon...
- Work in Progress
1997 Saturn SC2
2003 Saturn Vue
2000 Yamaha SUV1200 Waverunner
  #12
Old 04-15-2009, 01:47 AM
gixxer32404's Avatar
gixxer32404 gixxer32404 is offline
96 s10 4.3L
brake kicks back heard it's either abs motor $1000+ or abs sensor. I pulled fuse both lights now on. till I can have abs code pulled.
shift light doesn't work
tailgate hard to open
valve tap in the morning or belt
tps went bad setting off service engine soon light.
reverse light switch or sensor went bad ( no reverse lights)
seat handles brake
mirrors suck won't stay in place
heater core needs replacement
  #13
Old 04-15-2009, 06:20 AM
92chevysilvy's Avatar
92chevysilvy 92chevysilvy is offline
Super Moderator
88-94 headliner sagging. I know its not a huge deal, but it happens
88-94 Fuse panel
88-92 Glove box door
Hmmm, I'm kinda surprised nobody mentioned CAB CORNERS!
  #14
Old 04-15-2009, 08:02 AM
Mr_Shamrock's Avatar
Mr_Shamrock Mr_Shamrock is online now
Super Moderator
What about the good ole fullsize door panels. Those stupid push pins always break! You remove the door panel once and it's never the same! GM actually drastically improved that design in 1999 and on. Also the 88-94 arm rests on the door. They always crack around the mounting screw. BIG TIME!
  #15
Old 04-15-2009, 11:24 AM
EvansBlue's Avatar
EvansBlue EvansBlue is offline
Super Moderator
Send a message via AIM to EvansBlue
Oh god. The christmas-tree-looking pins. I hate those.
  #16
Old 04-15-2009, 08:04 PM
Super Moderator
Ok today here is what I came across...
2000 Silverado 4.3 liter...A/C blower barely blows any air out of the vents even on high. You can hear the blower blowing hard, but hardly any air comes out. Solution: Cabin filters were severely clogged - replaced and it blows like it is supposed to and smells alot better too!
Same truck...gas pedal sticks off ide - excessive pressure needed to be applied to the pedal to get the truck to take off. Solution: Another carboned up throttle body. Removed throttle body and cleaned thoroughly with throttle body cleaner. I recommend removing the throttle body completely on the 6 Cylinder Silverado's because it is mounted vertically and if not removed all the cleaner goes right into the motor and will probably set a catalytic efficiency code. They are easier to remove on the 4.3's anyway b/c the coolant isn't routed through it like the V-8's.
  #17
Old 04-19-2009, 08:05 AM
eagledax eagledax is offline
I have an 03 Silverado SS and the two things that I have noticed is a constant humm (I think it comes from the front half of the AWD trans) and a lot of wind noise from the back passanger window. I heard this is a common problem with these trucks. (It is not a full roll up window, it is a suicide half door and the window hinges out with the opening in the back). Even with these two annoyances I LOVE MY TRUCK!
  #18
Old 04-20-2009, 10:55 PM
red1997rod red1997rod is offline
plus one for the tailgate being hard to open. myself and I alone are the only people able to open it...
1995-1998 auto trans.. my dads 1995 went through 4 before the motor blew at 511,000 miles.. my 97's was rebuilt around 115,000...
plus one on the visor elastic stretching and becoming a nuesance(sp?)
  #19
Old 04-21-2009, 09:43 PM
joevonb joevonb is offline
proper front camber cannot be achieved
  #20
Old 04-27-2009, 05:55 PM
ShredSLED ShredSLED is offline
'99+ NBS:
slip yoke clunk.
Transfer Case encoder motor/sensor taking a dump.
hey joevonb, I've got a new set of upper control arm bushings that have an offset hole in them that can be rotated to acheive proper camber angles. If you're interested just private message me and we can work something out, I'll sell cheap (also have a brand new in box set of UCA's with ball joints and bushings too if you need as well).
Shralp' it Heavy.
48, 8898, awd, chevy, door, front, humm, install, knock, pin, repair, roller, sensor, silverado, ss, truck, vortec
