avalanche tryna cut off
i have a 2003 avalanche z71 it start up fine but every time i put it n drive it start to act as if its going to cut off on me then it start running back ok in like 30 seconds i changed the fuel filter thinking that was the problem when i start to drive it cut off before i can make the block but then start right up with no problem can any 1 help me.
It's a very easy procedure. Just get an aerosol can of throttle body cleaner and take the intake tube off. You will see all the black carbon built up in there. Personally I like to remove the entire throttle body, but most people just clean them on the truck. A small toothbrush comes in handy for the tough stuff. Get it as clean as possible especially where the throttle blade meets the inner wall of the throttle body. Good luck and let us know how it works out for you.
