Keyless Entry Problems
I have a 07' Avalanche that started having the keyless entry act up. First thought it was the battery going bad in the remote. Replaced and that was not it. You can lock and unlock the doors with the remote fine as long as you do not let the truck sit locked for very long. If you lock the car with the remote and let it set for a few minutes and come back and try to unlock it with the remote it will not unlock or lock, the remote acts dead. It you use the key and unlock the door then the remote goes back to working fine. Took into a mechanic friend of mine and he tried resetting the remote both with and without the scan tool and nothing worked. Has anyone experienced this problem and have any suggestions. Your input would be greatly appreciated.
onejediknight
07-31-2007 09:38 AM
bph
07-20-2007 04:18 AM
