97 Sonoma Battery Drain
Anyone had a smilar problem where the truck kept draining the battery when it was off? When it's on the volt meter shows 14 as the charge so the alternator is working. I am looking for a way to get this problem fixed asap since my corolla's windsheild just cracked on both sides... so I need to get the truck on the road asap
It's a 4.3 vortec if that makes a difference on how to fix it .
RE: 97 Sonoma Battery Drain
Dead short, that can be anywhere in the system. Simplest way? Shut off the truck and see if you can hear anything that shouldn't be on, I've seen a clock on aradio drain a battery (Pioneer). If that fails, break out a test light and start searching for shorts.
Doug McDevitt
02-27-2011 07:54 PM
JMASR
02-14-2010 10:40 PM
