Chevy/GMC Small Trucks Forum Discuss the Colorado, Canyon, Sonoma, S-10, etc here!
99-4.3L v6 coad 1345 cam/crank need help
Old 10-08-2007 | 03:46 PM
vtech1's Avatar
Default 99-4.3L v6 coad 1345 cam/crank need help
I have a high milage great running 99 s10- 4.3LV6.i've replaced the cam & crank sensores, did major tuneup.cleared coadseveral times and it still shows 1345 coad and wont pass inspection.i've replaced the pcmwith a matching used one,did'nt help so i put the original one back in.timing is correct and im thinking its a problem with the reluctor ring on the crankshaft in front of the timing gears and behind the timing chain cover.this is just a guess, i need to know how to clear this coad permanatly or fix the problem. i still drivemy truck on a daily basis,any quilifide suggestions would help. if you need more spacifics please contact me thanks.
Old 10-14-2007 | 01:39 PM
Streakn's Avatar
Default RE: 99-4.3L v6 coad 1345 cam/crank need help
Have you tried the wiring harness? Electrical codes and faults are hard to trace if a replacement part doesn't do the trick then you have to check the wiring.
Old 10-14-2007 | 02:51 PM
Argon's Avatar
what is 1345?..cam position?
Old 10-19-2007 | 02:19 PM
vtech1's Avatar
Thanks Streakin, Your the second tech that has brought that up and thats what i'm going to look into.
[sm=thanx.gif]
Old 11-01-2007 | 10:36 PM
vtech1's Avatar
Howdy, Argon. A code 1345 cam/crank positioning readout is a bitc.......... it is dealing with a random misfire thruout the drivetrain. Some readouts have stated, A loose sensorconnection and or valve train
problem.Great help the readouts are.
[sm=headbang.gif]
silveradoguy364
9
03-08-2011 09:01 AM
chrisbmo2000
01-31-2009 05:14 PM
chrisbmo2000
01-27-2009 10:14 PM
iascum
07-26-2006 12:05 AM
iascum
04-20-2006 02:03 AM
Quick Reply: 99-4.3L v6 coad 1345 cam/crank need help
