brake drums
RE: brake drums
Howdy, First off make sure you have the emergancy brake dissingaged. If you take the rubber plug out where you adjust the star wheel, on the brake inside the drum.You will see a spring loaded catch stopping the teeth on the star wheel. Good lighting is helpful, take a screw driver and push the catch back and away from the teeth, Take your brake tool at the same time your pushing the catch and adjust the star wheel to lossen the brake in the drum. The drum should slyd off.
[sm=type.gif]
[sm=type.gif]
lortech
09-19-2011 12:17 PM
STRAYDOG
11-04-2008 01:24 PM
