Chevy/GMC Small Trucks Forum Discuss the Colorado, Canyon, Sonoma, S-10, etc here!
A/C & Heater malfunction
Old 06-24-2007 | 02:42 PM
staruser's Avatar
Default A/C & Heater malfunction
I have an 83 Chevy S10 that the a/c and heater doesn't work correctly. The fan turns on. There's no a/c and the air doesn't work out any of the other modes except the defrost. I can slide the control to any position, but will blow out the defroster. I've tested all the electrical and seems to be fine. There doesn't seem to be any vacuum to any of the units under the dash and I can't find where the vacuum lines goes through the firewall and to where the vacuum lines will be connected to the engine. I'd rather not remove the dash just to locate the vacuum lines. Can you or anyone help?
Old 06-24-2007 | 06:47 PM
Argon's Avatar
Default RE: A/C & Heater malfunction
find your vacuum tank under the hood and make sure your getting vacuum to that
Old 06-25-2007 | 03:31 PM
staruser's Avatar
I'm getting vacuum at both sides of the vacuum ball. There's vacuum on the big tube and I can blow and suck through the small tube.
Old 06-25-2007 | 04:12 PM
Argon's Avatar
sounds like a dash issue then...you'll have to remove the head and manually check everything
markbark22
06-04-2013 02:38 PM
jhare5815
10-05-2011 10:18 AM
skoot61
02-15-2011 08:12 PM
jt1
08-24-2006 11:36 PM
tu3712
03-03-2005 12:16 AM
