Chevy/GMC Small Trucks Forum Discuss the Colorado, Canyon, Sonoma, S-10, etc here!
check eng light
Old 11-15-2007 | 04:59 PM
06Z71's Avatar
Default check eng light
How long does the check eng light stay on?? I didnt put the gas cap back on right. I5 motor
Old 11-15-2007 | 06:17 PM
Argon's Avatar
Default RE: check eng light
what a loaded question...here goes...class,pay attention..lol
gas cap loose...pcm runs a vacuum check on tank and discocers it....lite on.....
you tighten cap..
ok..ahem..
the pcm must run and see a "pass" 3 times on the tank.it uses a purge solenoid to pull vacuum on the tank,and see if it holds.
however...there is criteria BEFORE the pcm will ever even run test #1..
the tank must have over 1/4 tank gas in it.
the tank must be at least 1/4 empty
the ambient temp must be somewhat warm...not sure on the exact number
the engine must be brought to operating temp
of course,your trip is long enough for it to run
all that must be met before it tries test 1...THEN the car must be completeley powered down and cooled off before the next trip for test 2 to occur....
so...if you keep your gas tank full...it will never run
keep it empty.it will never run
make short trips,it will never run
on avberage,I'D say 3 days is a normal time for it to clear
Old 11-15-2007 | 06:44 PM
06Z71's Avatar
Argon thanks for all your info! Are you & myself the only 2 on this forum????????????? Never see anyone else !!!!!!!!
Old 11-15-2007 | 07:42 PM
Argon's Avatar
look on the right at top 10 posters...they check in quite a bit...
aldso a bunch of new guys from a defunct forum are around as well
Old 11-16-2007 | 05:50 PM
06Z71's Avatar
the light went out on the way home this afternoon!!!!!! THANKS AGAIN!!!!!!!
rockys
11-22-2007 01:11 PM
losttxn
08-26-2007 08:28 AM
losttxn
08-26-2007 08:26 AM
milspece6
04-04-2006 12:25 AM
milspece6
04-13-2005 07:10 PM
