@#$#@$^ wheel bearings melted my abs sensor
Old 02-14-2009 | 02:55 PM
cinch_rodeo's Avatar
Default RE: @#$#@$^ wheel bearings melted my abs sensor
Chrisbmo2000,did you find the plug yet?I know on my 95 Silverado it seems like the wire off the wheel sensor runs up next to the engine on the lower fender well before there is a plug.I have an ABS light on too.Don't know much about ABS other than I don't like it. I know how it works,what it does an all that but I hate trying to diagnose it.Will the OBDII scanners tell you wtf is wrong with the ABS?
  #12
Old 02-14-2009 | 05:10 PM
chrisbmo2000's Avatar
some OBD II scanners will others wont....no I havent found the plug yet but once it warms up a little bit I will look again your best bet is to start by cleaning and inspecting the wheel sensors them selves...I know I found alot of "metal" shavings on mine (from semi metalic brake pads) and check the "exciter" ring for chipped or cracked/ missing teeth
  #13
Old 02-14-2009 | 05:27 PM
Alrighty.I'll do that when the driveway dries out.It's been cold and raining here in the Buckeye state.If that dun work,I guess I'll get the hammer out =]
SweeperForce
03-07-2011 05:58 PM
goldguy
12-09-2008 01:22 PM
scotwea
03-26-2008 09:42 AM
tgalyean
10
02-15-2008 09:29 AM
sknaffl
03-03-2007 01:34 PM
Quick Reply: @#$#@$^ wheel bearings melted my abs sensor
