02 Silverado rear end leaning
Old 07-14-2007 | 07:50 PM
tslagan's Avatar
Default 02 Silverado rear end leaning
I have an 02 Silverado 2wd with 3 inch fabtech spindles up front and 1 inch blocks in the rear. For the past few months now, everytime I load a trailer or put any significant weight on the rear end, the left side drops about 2 inches lower than the right. Does anyone know what would cause this?
Old 07-14-2007 | 07:55 PM
72charger's Avatar
Default RE: 02 Silverado rear end leaning
You sure the block in the back left spring hasn't come out? I have been told they do that going over speed bumps and crap like that.
Old 07-15-2007 | 12:31 AM
chevy112488's Avatar
every once in a while, if you dont watch the extended u-bolts they give you for blocks, the nuts eventually with just vibrate off the end of it and your block could slip right out... you probably would've noticed that though...
Old 07-15-2007 | 12:12 PM
tslagan's Avatar
I had the front end lifted for a while before I ever put the rear blocks in, and it was leaning like this for a while before I put the blocks in. I was hoping to get a little added support from the blocks and I also put new shocks on the rear but it didn't help. I'm thinking the leafs might just be sagging but i'm not sure.
Old 07-15-2007 | 02:42 PM
off topic, but does the 3/1" make the truck sit level? i was thinking of getting 3/2 but i think its tilted more than that...
ryonwood
07-21-2012 02:31 PM
TJsierra1500
02-24-2010 09:11 AM
ABSPUD
07-18-2009 04:59 AM
garr58
12
11-29-2007 08:34 PM
dogpile
11-16-2006 06:13 AM
