02 Silverado rear end ratio??
What can I look for on the sticker in the glovebox that tells what gear ratio you have?? I believe it has a 3.73 or at least a 3.42. It's a heavenly optioned reg cab sb with a 5.3 it it skoots like no other 5.3 I've been in. So I think it has to be in the hear ratio??
Yeah look at the G code and see what you have...
Rear Axle Ratio
GQ1 -- AXLE REAR, STD RATIO
GT4 -- AXLE REAR, 3.73 RATIO
GT5 -- AXLE REAR, 4.10 RATIO
GU4 -- AXLE REAR, 3.08 RATIO
GU5 -- AXLE REAR, 3.23 RATIO
GU6 -- AXLE REAR, 3.42 RATIO
G80 -- AXLE REAR, LIMITED SLIP (POSITRACTION)
HC4 -- AXLE REAR, 4.56 RATIO
Rear Axle Ratio
Rear Axle Ratio
Rear Axle Ratio
Here's another thing I've never seen before. This truck has traction control, the button is where the four wheel drive switches would be. It will automatically disengage when the trans is dropped in 1st or you can depress the button and can be turned off that way as well.
Old International
12-17-2009 07:12 AM
