1500 cuts out randomly, no Msg on dash.
Old 08-13-2008 | 06:33 PM
mikie's Avatar
Default 1500 cuts out randomly, no Msg on dash.
2000 1500 Silverado w/ 124K miles, no problems so far until recently.
Truck fires right up every morning lunch and quiting time. On the road she shifts and revs fine but has started mis-firing or sputtering. There doesnt seem to be a pattern, atleast that I've noticed.
Replace -
Plugs, Wires, Cap&rotor, used Techron fuel treatment. Im going to check/clean AirIdle Control Valve tonight and replace FuelFilter and PCV since they're cheap.
I dont see anything on the display, so I dont know if a computer will show codes.
Anyone had issues like this? Man Im stumped any help will really be appreciated! Thanks
Old 08-13-2008 | 08:52 PM
mikie's Avatar
Default RE: 1500 cuts out randomly, no Msg on dash.
I finished with the fuelfilter and it dumped out some pretty bad looking gas onto a shop towel. Kinda Grayish.
The PCV valve was dirty but still worked. I went ahead and threw in a new one (@ $1.69 why not).
Ran pretty good on a test drive but the real test will be the daily grind. Still, I have a feeling there could be more wrong. Can it really be that simple? (yes, but is it likely to cause such bad stalling)
Old 08-15-2008 | 07:22 PM
mikie's Avatar
Truck is still stalling out. Doesnt happen when I turn the wheel, apparently some have had that issue but mine is non-specific to wheel location.
Shutters/sputters/stalls warm or cold.
I have read about CrankCase Position sensors going out. Common? Easy to do? CCPS is about $60 bucks.
Anyone...
Old 08-17-2008 | 12:57 PM
rxsteven's Avatar
You might want to get your alternator checked.
Old 08-18-2008 | 05:18 AM
Rhyse62's Avatar
Member
good chance of alternator my dads truck did the same thing
Old 08-18-2008 | 08:32 AM
jcbst12's Avatar
Take it to a shop and have them test the alternator. If you have a bad diode this can cause electrical problems and since our trucks run on computers I could see this causeing a stalling problem.
highroller152
04-01-2009 12:34 PM
dmccartyfan
10
01-19-2009 04:18 PM
alexmolinavr6
10-06-2008 05:53 PM
maxyboy
07-03-2008 07:28 PM
TonyT
07-24-2007 01:29 PM
Quick Reply: 1500 cuts out randomly, no Msg on dash.
