1500 vs 2500
Old 12-15-2008 | 07:39 AM
bad2006z71's Avatar
Default RE: 1500 vs 2500
the last US model 350 was in 2000 in the 3/4 ton (possibly 1 ton trucks) in the 88-98 body style. in 1999 you had the GMT400 style trucks with a 350 or the GMT800 style trucks with the 5.3 (half ton only). the only way to get a factory 350 in a half ton from that point on was if the truck was made and sold in Mexico. 2003 was not a transition year merely a year where the updated the front end and interior. the 350 ended in the 3/4 ton trucks in 2000 when the 2001 model year HD came out.
  #12
Old 12-15-2008 | 03:46 PM
Chevyalltheway's Avatar
Well I can't refute your statements, I don't know how, but it had a 350. nuff said haha. I had a 2002 Chevy with a 5.3 in it too though and I know that my Grandpa has a 2000 GMC with a 5.7 also.
Oh, back to the original content haha. I would suggest that if you care about what your truck looks like, avoid metallic paint on the 99-06's if at all possible, I have had horrible experiences and won't buy another truck that is not red or black. In the midwest the acid rain pits the white
  #13
Old 12-15-2008 | 04:08 PM
gpet6669's Avatar
The 2500 is heavier, therefor just by weight itwill get less mileage. As well as the bigger motor. The only other thing to consider is the ride quality while commuting. The 1500 will be more manuverable and be more comfertable while driving to work. You can always add a leaf or bag the backend to get the perfect ride while towing. I reccomend the bags, they will be more worth the money.
  #14
Old 12-15-2008 | 09:44 PM
DamnYankee's Avatar
Chevyalltheway:
'99 was the transition year for trucks, not 2003. Early '99 was the last year they used the 5.7l for trucks...they used them in vans til 2003.
And how can you hate a 6.0l but love a 5.3l? A 6.0l is a bored 5.3l...which simply means more hp.
And there certainly isn't a shortage of parts for any of the Gen III engines...
mudracer:
That 5.3l won't have 4.10's unless someone put them in there. Look in the glove box at the RPO sheet. If it has a GU6 it has 3.42's, if it has GT4 it has 3.73's, if it has GT5 it has 4.10's.
  #15
Old 12-16-2008 | 07:11 AM
bad2006z71's Avatar
DamnYankee: i agree, i went from an 06 5.3 to an 06 Vortec Max 6.0 and havent looked back, yea the mpg is alittle worse but the truck runs. the only bad thing is having to run 93 all the time.
as for not getting 4.10's from the factory with a 5.3, you could it was like $100 option when i was first looking at my 06. i cant confirm on reg or crew cabs, but i know you could get them in the ext cabs. but unless you specifically ordered a truck with them, they were rare. i think i saw one ext cab with the 4.10s and a 5.3 out of 3 months looking around and 4 different dealers. most had the 3.42 for MPG increase (yeah F*ing right)
  #16
Old 12-16-2008 | 09:05 AM
DamnYankee's Avatar
I think running 93 is a good thing. It keeps things cleaner, you get better mpg, more power, etc. It's worth the extra cost IMO.
  #17
Old 12-16-2008 | 09:58 AM
bad2006z71's Avatar
maybe, but the extra 50hp and 30 lb ft stock is worth it
just trying to save up for the tune. you think the stock 4l70 will hold up with 85% TM gone with line pressure increased some?
  #18
Old 12-16-2008 | 10:45 AM
wellmax's Avatar
Member
mud,
I have a 2000 model obs 2500 series with the 350 engine and 3.73 gears. I pull a TT that weights about 6500 # and on a long hill the 350 is just a bit light. As it only has 255 hp and 330# of torque.
If towing I would go with the heavier truck,as you know the golden rule of towing:
Its not what you can pull that counts, its what you can stop in a reasonable distance when some fool pulls out in front of you.
You want theskid marks on the pavement not in your pants.
my sons 06 2500 with 6.0 and 4.10 gets about 11-12 mpg around town.
  #19
Old 12-16-2008 | 05:36 PM
mudracer's Avatar
I have decided to go with the 1500 (pick it up tomorrow). It does have the 4.10 gears. I have attached the options for the truck. I will post later after I drive it for a few days. Thanks for everyones help.
AG1 - SIX-WAY POWER DRIVER SEAT
AJ1 - DEEP TINTED GLASS
AL0 - SENSOR INDICATOR INFLATABLE RESTRAINT FRT PASS
AM7 - FOLDING REAR SEAT
AU0 - KEYLESS REMOTE DOOR LOCK
AU3 - POWER DOOR LOCK SYSTEM
A31 - POWER WINDOWS
A95 - 6-WAY POWER DRIVER BUCKET SEAT
BVE - CHROME TUBULAR ASSIST STEPS *** DEALER INSTALLED ***
B30 - CARPETING, COLOR-KEYED
B32 - FRONT COLOR-KEYED FLOOR MATS
B33 - REAR COLOR KEYED FLOOR MATS
B71 - WHEEL FLARES
B85 - BRIGHT BODY SIDE MOLDINGS
CJ3 - AIR COND., DUAL ZONE MANUAL
C49 - ELECTRIC REAR WINDOW DEFOGGER
C7H - GVW RATING - 6,400 LB
DF5 - ISRV MIRROR W/COMPASS & TEMP
DK7 - INTERIOR CUSTOM ROOF CONSOLE W/ MAP LIGHTS
DL8 - DUAL PWR HEATED OSRV MIRRORS
DNR - DEALER INSTALLED EQUIPMENT
DT4 - ASHTRAY MUFFIN
D07 - CUSTOM FRONT FLOOR CONSOLE
EVA - EVAP EMISSION REQUIREMENT
E63 - FLEETSIDE BODY
FK2 - TORSION BAR SPRING ADJUSTMENT
FK3 - TORSION BAR SPRING ADJUSTMENT
FWI - FORT WAYNE PLANT
GT5 - REAR AXLE - 4.10 RATIO
G80 - LOCKING REAR DIFFERENTIAL
JF7 - BRAKES, 17" DISC/DRUM
KG3 - 145 AMP ALTERNATOR
KNP - HD AUX TRANS. COOLING SYS
KUP - THROTTLE CONTROL ELECTRONIC
K34 - CRUISE CONTROL
K47 - HIGH CAPACITY AIR CLEANER
L33 - VORTEC 5.3L 310HP ALUM BLK V8
M30 - 4-SPD AUTOMATIC TRANSMISSION
NC7 - FEDERAL OVERRIDE
NE1 - 50-STATE EMISSIONS
NP5 - LEATHER WRAPPED STEERING WHEEL
NP8 - AUTOTRAC ACTIVE TRANSFER CASE
NU4 - CAL EMISSION SYSTEM, LEV2 PLUS
NZZ - OFF ROAD - SKID PLATES
PDU - LIGHT DUTY POWER PACKAGE: *VORTEC 5.3L 310HP ALUM BLK V8 *LOCKING DIFFERENTIAL-REAR AXLE *HD TRAILERING EQUIPMENT
P25 - 17" ALUMINUM WHEELS
QJM - P265/70R17 OOR WOL TIRES
R5C - TIRE BRAND ALL BRIDGESTONE
R6M - NEW JERSEY COST SURCHARGE
R6Q - PACKAGE DISCOUNT NOT DESIRED
R9U - GM ACCESS - AUTOBOOK IDENTIFIER
R9Z - POMS EXPEDITE-SOLD ORDERS
SLM - STOCK ORDERS
TR3 - CHROME GRILLE
T96 - FRONT FOG LAMPS
UB1 - BASE AM/FM STEREO W/CD, CASSETTE WITH BOSE SPEAKER SYSTEM ADDED (REPLACES STD/OPT RADIO)
UQ7 - BOSE SPEAKER SYSTEM
UY2 - CAMPER/5TH WHEEL TRAILER WIRING PROVISIONS
VB3 - CHROME REAR BUMPER
VG3 - CHROME FRONT BUMPER
VR4 - WEIGHT DISTRIB. PLATFORM HITCH
VXS - COMPLETE VEHICLE LABEL
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XJM - TIRE FRONT P265/70R17-113S WOL R/PE ST TL OOR
X88 - CHEVROLET CONVERSION
YD3 - BASE EQUIP FOR SCH GVW PL-FT AX
YD6 - BASE REAR SPRING
YE9 - SILVERADO
YJM - P265/70R17-113S WOL R/PE ST TL OOR
ZJP - SPARE TIRE P265/70R17
ZY2 - TWO-TONE PAINT
Z71 - OFF-ROAD SUSPENSION
Z82 - HD TRAILERING EQUIPMENT
1SL - Z71 OFF ROAD PACKAGE INCLUDES: * DUAL PWR HEATED OSRV MIRRORS * REAR WINDOW DEFOGGER * WHEEL FLARES * POWER LOCKS & WINDOWS * REMOTE KEYLESS ENTRY WITH CONTENT THEFT ALARM * ISRV MIRROR W/COMPASS &TEMP * LEATHER WRAPPED STEERING WHL * BODY SIDE MOLDINGS
1SZ - LIGHT DUTY POWER PKG DISCOUNT
25U - DARK BLUE MET/SILVER BIRCH
59L - SILVER BIRCH METALLIC
6YH - COMPONENT FRT LH COMPUTER SEL
69D - DARK CHARCOAL
69I - DK PEWTER INTERIOR TRIM
7YH - COMPONENT FRT RH COMPUTER SEL
  #20
Old 12-16-2008 | 11:01 PM
6mins2live's Avatar
Cant wait to see pictures. Congrats on the new ride! Hope it all works out for ya.
Quick Reply: 1500 vs 2500
