180 degree thermostat
Old 04-19-2010 | 08:57 PM
josh29j's Avatar
Default 180 degree thermostat
180 degree thermostat in a 89 chevy truck 350 tbi motor. i have heard that is bad. i heard i would get worse gas mileage and worse performance.. is that true?? stock thermostat is 195...btw the truck is stored in the winter..never driven in winter
Old 04-20-2010 | 08:24 PM
HarderThanRocks's Avatar
if the thermostat needs replacing then go for it...
Old 04-20-2010 | 09:00 PM
No you will actually get better performance and your gas mileage difference is too infinitesimal to matter. with 160 degree stat you would have to worry but not for 180. I put a 180 in mine and didn't notice any difference. I figured that with an engine that old it probably doesn't need to run as hot as it did when new.
Old 04-22-2010 | 04:40 PM
timber74wolf's Avatar
Stock is a 195 correct? If you run a 180 it could hurt your mileage a little, but not enough to matter. Now a 160 will cause the truck to stay in the warm up cycle causing it to run rich I beleive which will cause bad gas mileage. However if you runa chip that needs a 160 like i Did when I had my 90 model 5.7 with the Hypertech Thermomaster. It did not hurt my mielage... if anything it seemed to increase it.
mic_in_chevy
08-15-2014 12:23 AM
jcormier89
08-18-2008 09:39 AM
bradthurman
01-15-2008 12:36 AM
street silver 1
10
09-19-2007 10:57 AM
Gearhead
01-13-2007 01:54 PM
