1979 GMC K3500 - No electric.
Old 04-04-2011 | 01:16 PM
thesmackdown's Avatar
Default 1979 GMC K3500 - No electric.
I am having a problem in that I don't have any electric on the truck. When I turn the key I am getting nothing. Turn on the lights - nothing. Radio - nothing. Etc, etc, etc.
Battery is at 12.7 volts. Ground line seems to be working ok.
I did get some intermittent times that I had things come on. But, it seems impossible to replicate the conditions.
Any thoughts?
Old 04-04-2011 | 07:36 PM
Is the positive terminal connected ???? Name:  cid_facesmack.gif
Old 04-04-2011 | 07:41 PM
cubpak89's Avatar
Default check your battery terminals they may be loose
check them they may be loose if they are loose they will cause that problem. also check the terminals themselves to ensure they are still tight cuase if they are loose on the baterry post it will do the same thing.
then check the wires to make sure they arent loose anywhere it is an older truck
Old 04-04-2011 | 07:55 PM
I have had both terminals off and they both are tight and the is no corrosion.
There is full voltage on the battery side of the coil.
Old 04-05-2011 | 11:04 AM
tasutt2009's Avatar
check the harness leading to the starter motor, you should find one or two fusible links
jdrisk
GM How-To's and Tutorials
11-30-2013 04:43 PM
edrob165
05-05-2011 09:43 AM
Cooper50
01-29-2008 05:53 PM
pulley
Vehicles for Sale
01-13-2008 10:26 PM
willhf1011
10-10-2007 05:42 AM
Quick Reply: 1979 GMC K3500 - No electric.
