1982 sctosdale problem
also check your bowl vent.......if the bowl is venting all the gas out as it sets you will have to crank on it to refill the bowl. this is a fairly common problem with the Q jet carbs the choke is the other issue.....both are well worth checking out...the easy way is to hit it with some carb cleaner first thing in the morning....if it fires and dies then the bowl is empty...if it fires and stays running then it could be a choke issue
