1994 gmc vortec 6stalling runs rough
Old 01-01-2011 | 08:01 AM
gerald60's Avatar
Default still working on problem stalling/flooding
i have almost replaced everything. egr valve,fuel filter,fuel pressure reg,idle air control assy,dist cap/rotor,throttle position sensor,ignition coil,checked ignition control modual ok,sensor MAP,coolant temp sensor. i guess the only thing left is the fuel pump but that is working fine its flooding the carb getting to much fuel. any other ideas help
  #12
Old 01-01-2011 | 09:46 AM
chevychase's Avatar
Only other thing maybe poppets on injectors stuck open.
You have poppets in injectors they open and close let fuel in cylinders, can get stuck open or closed.
If they get stuck open flooding issue.
  #13
Old 01-01-2011 | 10:18 AM
gerald60's Avatar
thanks will check that.but i can see ejectors open and close not sure.I have checked for any codes in computor only get code 12 means no other code, system normal. i bought a new oxygen sensor will try that.if that dont do it maybe ecm.im still checking for vacume leak no luck.
Brandoon
10-28-2019 11:26 AM
eaa1964
10
09-21-2010 06:10 PM
Stonehouse
10-27-2007 03:41 PM
RRaleigh01
09-07-2007 09:31 PM
eaa1964
05-21-2006 03:19 PM
Quick Reply: 1994 gmc vortec 6stalling runs rough
