1994 Silverado no heat
Old 12-09-2006 | 06:31 PM
speddle's Avatar
Default 1994 Silverado no heat
I have a 1994 Silverado 4 wheel drive v8 5.7, it has very little heat. I have flushed the radiator, cleaned the heater core, put in a new themastat. Checked the water pump seems to be working fine.
I discovered this problem after putting a plow on the truck and it over heated, I have also changed the fan clutch. Can anyone please help.
Thanks
Old 12-10-2006 | 02:36 AM
under construction's Avatar
Default RE: 1994 Silverado no heat
ORIGINAL: speddle
Thanks
does it ever warm up? cause im having kind of the same problem. but my truck will start gettin warm after a long drive, actually it'll begin to get warm right when im pulling into work way after the engine and properly been warmed up and drivin on the freeway. Im trying to fix my problem right now, so if its the same thing let me know and when i find out ill keep you posted.
Fmotoring
05-07-2012 10:34 PM
rlschne
12-27-2010 11:53 PM
Aluminator
8
01-06-2010 02:49 AM
MIBPreacher
11-19-2007 07:00 PM
majordad
11-04-2007 01:37 AM
