1996 driveshaft removal help
Old 03-12-2011 | 06:32 PM
stryped's Avatar
Default 1996 driveshaft removal help
I am having trouble removing the driveshat out of my 1996 chevy.l It is one piece. The front is a yoke going into the transfer case, The back is held in with bolts. manual says to remove bolts and drop driveshaft but it wont budge. What am I doing wrong?
Old 03-13-2011 | 01:18 PM
warpath's Avatar
Hit that **** with a hammer it should break lose.
Old 03-13-2011 | 01:30 PM
chrisbmo2000's Avatar
DO NOT hit it with a hammer......a pry bar will remove it safely with out the possibility of missing and denting the drive shaft......if it has been in there a while it will take some doing......you need to remove the drive shaft from the axle first...then at the t case
Old 03-13-2011 | 10:55 PM
93Z71's Avatar
Yes slip a small pry bar inbetween the U joint and the rear end yoke and push gently to get it free be careful to not drop a u joint cap as you may loose a needle bearing or two
Old 03-14-2011 | 06:42 AM
warpath's Avatar
I meant with a dead blow hammer so it wouldnt dent the drive shaft.
chevyrules
11-16-2009 08:30 AM
larryntripp
06-08-2009 05:20 PM
scotwea
04-03-2008 10:41 PM
iward05
9
03-01-2007 08:34 PM
Remi762
08-23-2006 02:19 PM
Quick Reply: 1996 driveshaft removal help
