1999 Z71 Check engine light does not come one.
Old 02-06-2011 | 09:46 PM
Xware's Avatar
Default 1999 Z71 Check engine light does not come one.
i have a 1999 Silverado Z71 with the 5.3 v8. the truck has codes but the check engine light does not come on. it does display other messages like. washer fluid low. change oil and low fuel . but even tho it has codes nop check engine light. any ideas?
Old 02-06-2011 | 10:38 PM
Somone pulled the bulb more than likely. Have you had the truck long? Has it ever worked?
Old 02-06-2011 | 11:33 PM
RUFFNECK4LYFE's Avatar
My cruise and high beam indicator lights went out and so did the one for the SES. Most likely the bulb on yours. Very easy to replace.
Old 02-07-2011 | 12:21 AM
Xware's Avatar
does it have its own light? i thought it came thru the message center like the other warnings?
Old 02-07-2011 | 12:23 AM
No it sits between the cruise and high beam. The one your talkin bout is the info center. There is also an SES light. It uses the 914 bulbs I believe.
Old 02-07-2011 | 12:32 AM
Xware's Avatar
oh ok i was thinking it showed up there for some reason. i will check for that bulb
Mugs
01-09-2012 12:25 PM
09GMCSierra
07-17-2011 11:37 AM
pierce12
03-27-2011 08:12 PM
Ted J
02-13-2009 11:53 PM
