2000 Sierra 5.3 Starts and dies
Old 11-14-2007 | 08:47 AM
paintexpt's Avatar
Default 2000 Sierra 5.3 Starts and dies
Lately I have had my 2000 Sierra 5.3 acting up, once in a while it will start and die, idle is low 500 sometimes 300, I can keep foot on gas to keep runnung, when I let off it dies,after a while it will straighten it self up, seems to be getting worse, any ideas? Thanks
Old 11-14-2007 | 11:05 AM
Argon's Avatar
Default RE: 2000 Sierra 5.3 Starts and dies
a few possibilities...idle motor...tps...
gm had a reflash for this as well
Old 11-14-2007 | 11:26 AM
paintexpt's Avatar
Thanks I will check those, I was also told, it was being stupid due to a battery that went dead and it neededthe pcm torelearn the idle, I followed the GM procedure process of running in drive with e-brake on & a/c off for 5 min, then in park for 5 min, then shut off for 30 sec, also cleaned throttle body with brake clean and a brush, hopefully that worked, if not I will check the others and let you know, I guess this can happen anytime you change the battery or disconnect the battery
dkrood
04-01-2018 03:43 PM
2bfeard
12
07-19-2015 01:28 PM
skipMore
08-05-2006 04:13 PM
skipMore
08-03-2006 06:49 PM
general z
08-01-2006 05:58 PM
Quick Reply: 2000 Sierra 5.3 Starts and dies
