2000 silverado loose steering, advice for replacement...
Old 05-04-2012 | 03:12 AM
markbark22's Avatar
Default 2000 silverado loose steering, advice for replacement...
Very loose steering box. Around 15 MPH I get a gentle shake in the front end but nothing after that. The steering is sloppy and I need to fix. Best solutions?
Thanks
Mark
Old 05-04-2012 | 04:42 PM
NullHead's Avatar
Check the front end out and make sure the other suspension components are good, make super sure it's not your pitman or idler arm - if everything is fine, check steering shaft U joints. If all is good, replace the gearbox.
Old 05-07-2012 | 11:27 AM
markbark22's Avatar
Checking all that and will let you know. Thanks for the advice.
Scagnasty
07-15-2014 09:47 AM
hillbilly73
01-04-2009 12:08 PM
wickedlester
08-11-2008 11:43 PM
gbroad23
08-25-2007 11:26 AM
scauntay
01-22-2007 11:03 PM
