2001 Gmc sierra 3500/ int low fuel press.
Old 04-21-2008 | 08:03 AM
Carbuff71's Avatar
Default 2001 Gmc sierra 3500/ int low fuel press.
This one has got me puzzled,6.0 litre efi ,had to be towed home,would start but not enough power to move,checked fuel press.20-23 psi with or without regulator vaccum line on,dual tanks,pumps were replaced at dealer 2 years ago,replaced filter,no improvement.
Old 04-21-2008 | 09:17 AM
Argon's Avatar
Default RE: 2001 Gmc sierra 3500/ int low fuel press.
PUMP IS BAD...only 1 pump makes psi to send to the engine...the aux pump just movesfuelfrom tank to tank
Old 04-24-2008 | 07:50 PM
Carbuff71's Avatar
Thanks,problem solved,pump was bad sock was also full of mud and rust,found cut filler neck vent hose behind rear tires,also rusted fuel lines from front tank to fuel filter.WOW not a cheap fix.
merry
09-15-2008 04:10 AM
DennisT
14
03-25-2008 12:37 AM
obspec
Vehicles for Sale
01-23-2008 01:12 PM
funhemi
02-12-2007 11:02 PM
Quick Reply: 2001 Gmc sierra 3500/ int low fuel press.
