2001 GMC sierra signal switch replacement instructions.
im looking for or where could i get instructions (without having to buy) on how to replace my turn signal switch for my 2001 GMC pickup, 3/4 ton, 4wd automatic..any help or direction or information would be greatly appreciated!
Pull the steering wheel and lock plate,take the 3 screws off the assembly,unplug the harness at bottom,pull the wiring out, to replace just run a wire coat hanger through the column from the bottom, and hook your new wiring to it to pull it through the column, replace srcews and wheel,hook up wiring,you're done.
sofasurfer
03-20-2011 05:14 PM
EGT1
10-23-2009 08:03 AM
