2001 silverado 1500 4.3 2 wheel drive
#14
RE: 2001 silverado 1500 4.3 2 wheel drive
CHECK THIS...THE IGNITION COL..ON THE PASSENGER SIDE OF THE ENGINE...LOOKE CLOSELY AT THE PINK WIRE GOING TO THE PLUG ON THE COIL...GIVE HER A SLIGHT TUG AND SEE IF ITS BROKEN...TRHAT WILL CAUSE YOUR PROBLEMS
#15
no pink wire problems. we replaced the relay, and will now change the fuel filter to make sure it wasn't bad gas. right now running great stationary while warm, and turning ofdf and starting right back up...Thanks for your help..it is hard not being here to see exactly what happens...John
#19
HELP... STILL HAVING PROBLEMS DOES MY 2001 SILVERADO 4.3 HAVE AN IGNITION MODULE, AND IF SO DOES IT CONTROLL THE FUEL PUMP....WHEN THE TRUCK IS COLD IT STARTS RIGHT UP, BUT WHEN TO TEMP IT EITHER SPUTTERS OUT OR WHEN YOU TURN THE TRUCK OFF IT WONT TURN ON UNTIL COLD JOHN
#20
After about two weeks it acted up again..first time it sputtered out then today after replacing the purge valve ran fine till I turned the truck off then wouldn't turn until compleetly cold. My friend is wondering if I have a ignition module, if so does it controll the fuel pump, like if it were bad and not sending enough volts causing the fuel pump to over heat? Thanks John
Tennessee0318
03-22-2012 04:39 PM
darkfire5000
01-28-2009 12:28 AM
peli
07-23-2007 03:13 PM
