2001 silverado drive train troubles
Old 10-15-2008 | 08:34 PM
wrimar61's Avatar
Default 2001 silverado drive train troubles
hi i'm new to the forums and have some maintainance question for my 2002 Silverado Ext Cab 4.8L V8 Auto 4x4
When I even ease in drive sometimes i will hear a creeking/cracking sound
and when I go from P to D or change gears at all for that matter in will jerk and sound like a slap, also while moving when the truck swithes gears i will get a little jerk.
common sense tells me it seems like it time for a new tranny with roughly 75k miles on it
but was wondering it may be anything else before I spend the cash on a new one.
Also, I wanted to change out the U joints to see if that would fix it and after spending around 4hrs and not getting any caps off the old U joints i gave up, any suggestion or tips
Old 10-15-2008 | 08:50 PM
MrLM7's Avatar
Default RE: 2001 silverado drive train troubles
U joints...
Old 10-15-2008 | 10:06 PM
NewVagus's Avatar
How many miles? It could be several things. There are things to look at with high mileage vs lower. If you are checking the u-joints remember to jack up the rear end to check.
Old 10-23-2008 | 08:17 PM
chuck4379's Avatar
defintley check your u-joints first. cheap fix in the garage, expensive fix if it lets go on the freeway.
Old 10-24-2008 | 08:47 AM
jcbst12's Avatar
I have the same thing going on with mine, especially when shifting from drive to reverse. I also get a slight vibration between 60-70 MPH. It should be the U-joints.
Hey, how much of a bitch is it to remove the u-joint closest to the yoke? It looks like a bitch to get out! Maybe take it to someone with a press?
Old 04-12-2010 | 06:44 AM
aja72's Avatar
Banned
I also suggest you to check U-joint & gear box first because i think after check this definitely you will know about problems.
05 GMC
09-13-2012 06:16 PM
Ron Green
12-26-2008 09:31 PM
jdemerich
19
05-21-2008 08:56 PM
bad2006z71
04-01-2008 09:54 AM
Chevy A
05-02-2007 12:15 PM
Quick Reply: 2001 silverado drive train troubles
