2002 1500HD 4wd question
Old 11-24-2018 | 04:00 PM
Caspers Ghost's Avatar
Default 2002 1500HD 4wd question
Hello all,
I have a 2002 Chevy Silverado 1500HD. 6.0 engine. The 4wd does not work. The fuse is good. When the buttons on the dash are pushed they will stay lit when switched to 4 lo, 4 hi etc. I can hear some activity in the transfer case when the buttons are pushed. I pushed 4 lo and drove a few hundred feet but it did not go into low gear. I do not hear any grinding and other nasty noises in the transfer case as I had on other Silverados when the transfer case went bad.
I have a basic scan tool and no codes come up and no service 4wd lights are on in the dash. No check engine light.
I originally thought it would be the front axle actuator but since it won't go into 4 lo I thought maybe the motor on the transfer case.
Anyway, as I get older I like to do as little exploring as possible and don't want to just start replacing parts. Any suggestions on tests I can do to narrow it down will be appreciated.
Thanks in advance.
hobowar
06-06-2014 08:50 PM
Nibin
08-20-2013 10:04 AM
Nibin
08-06-2013 03:04 PM
mulscomanagement
09-11-2010 01:12 PM
1deltad2
12
07-03-2007 07:44 PM
