2003 1500HD Transfer Case Replacement/Rebuild
Old 03-25-2013 | 11:17 AM
grtaylorjr's Avatar
Default 2003 1500HD Transfer Case Replacement/Rebuild
I'm looking for a reputable online company who can sell a Transfer Case to me.
I have found a few but I'm not sure which "option" I have.
What does SS mean regarding this T-Case?
I have a 2003 Silverado 1500HD LT 6.0L V8.
The current transfer case has the following info on the plate:
Model 246 GM
ASSY NO. 12577835
Serial NO. 71702K1
Ratio 272
I have the push button 4WD selector.
Old 03-25-2013 | 04:13 PM
Drive Train .com comes highly recommended by SPEED network.
1999 to 2003 Silverado 1500 246GM model Tcase (electric shift) 27 spline
$1,099 your cost +$350 Refundable Casting charge
Why are you replacing your Tcase?
Old 03-26-2013 | 10:29 AM
grtaylorjr's Avatar
Hey. Thanks for responding.
A couple of weeks ago I started hearing a ticking sound coming from underneath my truck. It was coming form the transfer case. I bought some Autotrac II fluid and prepared to change the fluid. I opened the drain plug and five drops of fluid came out--that is all that came out. It had been empty for who knows how long. I filled it and drove it. The sound went away but I noticed that I had a leak that I never noticed before. I researched and found that I had a well-known problem (pinhole due to pump rub). I patched the hole temporarily with JB Weld but it still weeps. Now I'm hearing an intermittent scraping sound. Sounds horrible for about 4 seconds, but goes away quickly. Since I cannot pinpoint the sound, I assume that the T-Case is toast after (years?) of low-to-no fluid. A rebuilt case with a warranty sounds like the best bet in this instance since there are possibly hundreds of dollars worth of parts that need to be replaced inside the T-Case. The rear housing also needs to be repaired.
As for the scraping sound, I hope it goes away with the T-Case swap. I'll update the thread when I know.
makin_8@hotmail.com
12
10-18-2021 01:09 PM
wannarex
04-16-2014 11:09 PM
easystreet
9
02-09-2011 05:09 PM
jrk99
03-09-2010 04:05 PM
bryan2000
02-28-2006 01:55 AM
