2004 Silverado window cable
Hi all; New to forum today.
I have a 2004 Silverado crew cab. The drivers window quit working today (power windows). I removed the door panel and noticed the cable is broken at the motor. Can I just replace the cable? Where can I find instructions? Thanks RAC
all true! Although I've only had one pass. side replaced. ...and don't ask why but I had the dealership do it. If I recall correctly, I think they raped me for somewhere near $350-400 just to do it. They said the part, can't remember if they called it the "regulator", or the "actuator" or something costed $200-250 alone, since you have to purchase the whole assembly.
ridiculous.
I just changed my drivers side assembly for the second time. I purchased an after market unit off of EBay for $40. I would almost recommend buying an OEM unit instead of the cheaper after market units. The reason being the after market units tend to run a lot slower than the OEM unit. As far as installation is concerned it's not all that difficult. I used duck tape and taped the window in the up position. Than all you ned to do is install the kit and bolt it all in. Hope this helps.
timbo
03-29-2006 08:16 PM
