2005 2500HD 6.0L 4x4 transfer case question
Old 12-12-2009 | 06:34 PM
Blindice's Avatar
Default 2005 2500HD 6.0L 4x4 transfer case question
When I try and turn or load up the 4 wheel drive the front in makes a huge jolt. it works in 4 wheel drive but does this after it loads up. Both Cv axl's have been done already as well. I am guessing it has something to do with the transfer case. I also can't manually shift it into 4H while moving even slow with out it grinding. Any ideas on where to begin and what I need to get replaced?
Old 12-28-2009 | 07:48 PM
joe2705's Avatar
try to wiggle the driveshaft on my truck (same as yours) the bearings on the outputshaft where shot.
Old 12-29-2009 | 07:22 AM
Blindice's Avatar
we have done that and that is not it. Its not what is making the oil go black in the transfer case.
Old 01-01-2010 | 10:14 AM
REALRAPTOR04's Avatar
Default Transfer case
The extra oil in the transfer case is caused by the frt seal in the transfer case being hard and cracked must use autotrax blue oil only. If oil in case over full replace seal. The extra oil in the case will cause all kinds of probs
DEW
09-06-2011 07:02 AM
jschoend
05-26-2011 12:15 PM
DEW
08-15-2010 07:44 AM
urnhart
02-05-2009 12:06 AM
Rosser
08-13-2006 10:19 PM
Quick Reply: 2005 2500HD 6.0L 4x4 transfer case question
