2008 2500HD Rear End
Old 09-14-2008 | 07:58 PM
nathan89's Avatar
Default 2008 2500HD Rear End
Hey guys, I am new to the forum.
I have a question that I hope someone can help me with. I have a 2008 Silverado 2500HD with the 6.0L gas, 6 speed auto, and 3.73 gears in the rear end. I use the truck to pull a 31' Coachmen Adrenaline toy hauler that weighs in at a little over 10,000 pounds loaded. My problem is that the truck has to work a little too hard to pull up some of the larger hills on the highway. It will still make it to the top of the hills and everything, but really doesn't want to go much over 40-45 mph.
So, my question is, is it possible to have the dealer put 4.10 gears in the rear end?
Old 09-14-2008 | 08:24 PM
hunt4game29's Avatar
Default RE: 2008 2500HD Rear End
Yes the dealer can change it to 4:10s that would do alot better for you on towing. Or find a local auto place to do it. It might be cheaper. Also you will have to change the pcm to read the new gears.
Old 09-15-2008 | 03:44 PM
04BLKCHEVY's Avatar
I would imagine that they would come with 4.11's already. My 04HD wit the 6.0 came stock with 4.11's. Your best bet is going to a 4 wheel drive shop or a gear shop to do your gears.A dealer would just charge you double.
Old 09-16-2008 | 12:02 PM
jcbst12's Avatar
I agree with the gear swap idea but a new PCM isn't needed, just a tune.
Its either that or get a more aggressive CAM, a tune, K&N air filter, intake maybe, stuff like that to boost the torque.
Old 09-21-2008 | 03:43 PM
upsman105's Avatar
I have the bigger rear end in my truck, set up with the same motor and tow about the same weight. Still have to slow down to 40 or 45 going up hills. The rear end swap will help, but don't count on it making all the difference in the world... for the money you pay to swap them out, I doubt you will get the results you are looking for....
Old 09-22-2008 | 06:49 AM
Argon's Avatar
ya need more truck,not a different ratio
Old 09-22-2008 | 07:48 AM
jcbst12's Avatar
Maybe a diesel or a BB 3500, least then you would have better braking power not to mention the better pulling power.
bam2880
07-04-2011 04:25 PM
LtDan
05-06-2011 02:33 AM
ABSPUD
07-18-2009 03:59 AM
Drifter59
05-15-2009 01:11 AM
sqdqo
03-21-2009 06:42 PM
Quick Reply: 2008 2500HD Rear End
