2500 vs 2500HD real axle specs
Old 09-15-2006 | 03:27 PM
chevy2500in_tx's Avatar
Default 2500 vs 2500HD real axle specs
I currently have an '04 2500 crewcab that I use to pull a 8,000lb travel trailer (loaded) with a 1,300 lb tongue weight. 6.0L gas V8 with the standard 4.1 rear axle ratio and always use a weight distributing hitch when towing. The max towing capacity for my truck is 8,300lbs. I noticed that the max towing capability of 2500HD (same 6.0L but with a 3.73 rear axle ratio) is 10,200lbs, or almost 2,000lbs more. The suspensions for both the 2500 and 2500HD appear to be the same. Can any one tell me if the extra towing capacity is simply a function of the different axle ratio? Does the 3.73 axle have a higher weight rating?
Komrade
03-23-2013 07:42 PM
Dangerous
05-24-2010 09:27 AM
popo
02-24-2007 11:48 AM
popo
01-29-2007 05:24 PM
leake79
07-05-2006 09:53 PM
Quick Reply: 2500 vs 2500HD real axle specs
