3 problems with 6.2 diesel 4x4 1/2 ton
Old 10-11-2007 | 09:54 PM
honda4by's Avatar
Default 3 problems with 6.2 diesel 4x4 1/2 ton
Hello All
New to this web advice...but am at wits end.
My truck...92 Chevy Sierra extended cab 4x4, 6.2 diesel...400,000KM on truck, 70,000KM on motor.
#1. Tranny will go into lock-up on hard accelleration (past 40mph), but when I ease off to posted speed (55mph) it comes out, then goes in...etc.
I switched the TPS unit with a tps from a 88 diesel van.(wire harness was different, so I re-wired the old end onto the new tps I got off the van) Now its really hard going into lock up..any advice on this one?
# 2. Where is the actuator (electric)that controls the defrost flap for the heat that blows on the front windowlocated? Its not opening up all the way..only very little...[>:]
# 3. When I shift the 4 wheel drive shifter into 4x4, no light comes on in the pannel, saying its in 4x4....its locks the fronts briefly (drive about 20 ft), then I loose the front drive....no longer in 4x4.
The actuator that screws into the front axel seems to be working, as I had it out and shifted into 4x4 and the piston came out and stayed out...I evenbought another actuator and tried it..same thing...any advice on this problem?[8D]
I'm guseeing electronics on all 3 problems...but dontknow where to go from here...I hate paying $80.00an hour for atricky, yet very simple fix.
Thanks all for your help in advance.
Steve
Old 10-15-2007 | 08:05 PM
Cracker's Avatar
Default RE: 3 problems with 6.2 diesel 4x4 1/2 ton
You are way outside my level of expertise.
Didn't want you to feel ignored.
Old 10-16-2007 | 07:31 AM
Tankfxr's Avatar
I did alot of work with the 6.2 when i was in the army but most of that was engine work so im lost on you questions also sorry.
In2Trux
12-06-2013 10:26 PM
TruckEnthusiast505
08-01-2013 11:35 PM
chino11368
04-07-2013 07:10 PM
Dozer
03-04-2008 08:18 PM
rutwad
Vehicles for Sale
02-12-2008 01:34 PM
Quick Reply: 3 problems with 6.2 diesel 4x4 1/2 ton
