33" tires on 3" lift?
Hey guys, my friend is thinking of buying a 2004 Chev 1500.
She wants to get 33's on it, but she isn't sure how big of a lift too get. Would they fit on a 3" lift, or would you have to get bigger? Also, what kind of tires would be best to get.
Thanks!
Thanks!
Well her and I both live in the country, so she will probably want tires for all terrain, since there's always a good mix out here. What brand do you think Would be best?
In general I would say yes it could work.
But, you could have many different variables working against you.
Be aware there are many different tire sizes the equate to 33"
A 3" lift may give you adequate clearance but,
Your rim off set may play a factor whether your tires rub or not.
A good tire shop will work with her to find the biggest tire she can put on her truck with the lift it has and the rims she is going to use.
If the tire shop won't work with her? Go to another that will.
Ill tell her to look into it soon.
Thanks for your help guys
Selecting a brand is subject to personal opinion and Brand loyalty. I did my research for the best wearing tire for my 3/4 ton and found BFGs to last the longest.
I'm currently very happy with my 265 70R 17 BFG Mud and snow all Terrain.
Visit our forum sponsor tirerack.com and select a possible tire and click on user reviews
You will also find some brands are closer to the advertised size than others.
Extreme examples from the past was 44" ground hawgs about the same height as 40" super swampers. Interco is know for being closer to advertised sizes. Had 35" Gumbos that measured just over 33" in actual height.
