4.10 gear need advice!
Old 11-27-2007 | 05:12 PM
jester's Avatar
Default 4.10 gear need advice!
I installed the 4.10 gear with posi trac (daily driver). IT made a big differance in RPM and power. I ajusted my super chips programmer for the gear.
The problem I am having is at 90MPH I get a buzz or harmonic vibration, whenit hits 100MPH its gone then comes back at 90MPH and is fine below 90MPH. Has anyone herd this before?
I talked to Pyle Brothers the guys that installed the gear and posi,theysay their is nothing in the rear end that can make a vibration at 90MPH.
So I got a second opinon and the guy at Green & White says he has the 4.10 gear and it will do that at that speed because it is spinning its *** off. Should I have installed the race posi?
Old 11-27-2007 | 06:22 PM
smoke20's Avatar
Default RE: 4.10 gear need advice!
I don't know about the race posi, but if you have a vibration that shows up only at certain speed, then you may have a wrong size shim issue. These have to be correct within .001 of an inch. I would not be suprised if they have to redo it.
Old 11-27-2007 | 08:09 PM
jester's Avatar
Pyle Brothers I have herd from many shops that they are the best when it comes todifferental rear ends. PB is a race shop that works on race cars and trucks & pro-stock. I watched this guy for 4hours install the 4.10 and posi and it looked professional.
New seals, berrings, the entire rear end was gutted. Not sure about a different scim.
Old 11-27-2007 | 08:36 PM
Cracker's Avatar
What brand posi?
Old 11-27-2007 | 08:47 PM
jester's Avatar
Dura Grip 8.5 30s
Old 11-27-2007 | 08:50 PM
Cracker's Avatar
I am unfamiliar with that brand. Sorry, but, no advise here.
Old 11-27-2007 | 09:21 PM
jester's Avatar
Damn!
Old 11-27-2007 | 09:22 PM
jester's Avatar
Old 11-28-2007 | 12:24 AM
72charger's Avatar
You know my Supra came stock with 4.30 rear end gears.
Old 11-28-2007 | 08:46 AM
jcbst12's Avatar
I've heard of rear ends "singing" before. It was always a fluid and/or manufacturing issue. (Ex. Some gears just make noise period.) Depends on how bad it is I guess.
