5.3L WHAT IS THE STOCK HORSE POWER
Old 03-06-2008 | 02:02 AM
06silverado22s's Avatar
Default 5.3L WHAT IS THE STOCK HORSE POWER
I HAVE A 06 SILVERADO CREW CAB AND I WAS WONDERING WHAT THE STOCK HORSE POWER AND TORQUE? I WAS ALSO WONDERING WHAT KIND OF HORSE POWER I HAVE: I HAVE A K&N INTAKE, FLOWMASTER EXHAUST, AND THEENERGY MAX PROGRAMMER. I WANT TO GO TO THE DYNO TO SEE WHAT THE TRUE POWER I HAVE. DO YOU THINK THAT I COULD BEAT A O6 DODGE CREW CAB. THANKS GUYS
Old 03-06-2008 | 07:30 AM
bad2006z71's Avatar
Default RE: 5.3L WHAT IS THE STOCK HORSE POWER
your stock power to the engine is 295hp@5200 RPM. torque is 335ftlb @ 4000 RPM. probably take 15-20% off to get rear wheel power.
I have the same setup you have but in an ext cab. the dyno sheets from their websites state:
K&N: +11.92hp @5367RPM
Hypertech: 87 octane=250hpmax to rear wheels @ 5250RPM, 279lbft of torque max @ 3750RPM.
flowmaster maybe mutiply your base hp and torque by 5%.
i doubt you could beat a hemi but maybe. i still get smoked by Nissan Titans. but the 3.e42 gears dont help towing or draging.
what gears do you have?
i would love to know the results of your dyno run when you get it done.
good luck
Old 03-06-2008 | 08:49 AM
jcbst12's Avatar
I believe mine stock is 275, but only 245 or so at the wheels.
Not bad considering:
99 Ford 4.6: 230
99 Dodge 4.7: 230
99 Toyota (whatever their small V8 was before the 5.7): 230
But the Predator was the best improvement. I get 4% more out of 87 octane (11hp), 6% more out of 91+ with that alone (16hp). Then if I got another 6% with the intake, TBS and Stat, then I figure I have the potnetial for about 300 at the crank. Maybe 275 at the wheels.
Old 03-06-2008 | 09:22 AM
legacy's Avatar
The guys on ls1truck dyno'ed some of there trucks and stock hp for a 5.3 was about 230-240hp. With those mods, hitting the wheels you probably got like 255
Old 03-06-2008 | 10:02 AM
jcbst12's Avatar
NOPE! We are both wrong!
If this is correct, this hurts!
http://www.hypertech.com/media/dynoc...%20-%2053l.pdf
Hell I bet my 91 put down more than that when I was done with it!
Old 03-06-2008 | 10:28 AM
jcbst12's Avatar
But they have the 00-01 making 261 stock at the rear wheels! Something doesn't smell right.
Old 03-06-2008 | 10:43 AM
knoxy's Avatar
wouldn't measurement be straight from the wheels only though?
to get nominal horsepower of the engine it self is simply:
nhp = 7 x area of piston x equivalent piston speed/33,000 (wikipedia.org)
therefore the dyno would only be measuring the HP at the wheels.
or am i out to lunch?
Old 03-06-2008 | 10:57 AM
bad2006z71's Avatar
yea a dyno measures power at the rear wheels which is the power that matters.
Old 03-07-2008 | 07:58 AM
legacy's Avatar
So that is saying we get 190hp at the wheels? no.....i dont wanna believe that....
Old 03-07-2008 | 08:39 AM
bad2006z71's Avatar
No from what ive been told you usually take about 15-20% away for transfercase, transmission, driveshaft, and all that stuff. so 295 @80% would roughly be about 236-240 at the rear wheels.
