91 heater vents
Old 10-02-2009 | 08:27 PM
7060's Avatar
Default 91 heater vents
For some reason my vents do not change from floor heat. The screen on the dash changes when I hit it but it keeps blowing floor heat, it may blow a little defrost but mostly on the floor. Is there a motor that changes the airflow? What could go wrong? Any help would be great. thanks
Old 10-02-2009 | 08:33 PM
RUFFNECK4LYFE's Avatar
There is a blend door behind the glove compartment. Not sure if its electrical or works off vacum. Feel or look back there and see if you can hear a hissing or loose hose while the truck is running. If not then you might have an electrical blend door.
Old 10-02-2009 | 08:39 PM
There is also an electric motor that is probably either bad or one of the metal arms has come loose. It is either behind the glove box or under the dash just above and towards the middle a bit of the gas pedal. I can't remember which that year.
Old 10-05-2009 | 09:19 PM
7060's Avatar
Do you have to take the dash board off to fix it?
Old 10-06-2009 | 07:03 AM
No you can fix it from underneath.
RC
12-30-2009 09:05 PM
joegmc
06-25-2009 12:14 AM
WALT258
01-21-2009 07:07 PM
74orangedart
11-29-2007 07:53 PM
deanravn
05-14-2006 01:17 PM
Quick Reply: 91 heater vents
