95 running problems
Old 01-09-2010 | 05:06 PM
mblanchard85's Avatar
Default 95 running problems
Hello i have a 95 silverado 4x4 5.7 and im having trouble with it stalling out in gear when i hit the gas i pulled the engine codes and i was wondering if you guys had any suggestions where i should start
42 - Electronic spark timing (EST) circuit - open or shorted
Direct ignition system (DIS) fault - bypass circuit open
or shorted to ground during engine run
Fuel cutoff relay circuit - open or shorted to ground
-i checked the est first thing and it is plugged in-
44 - Lean exhaust indicated (Left side on dual oxygen models)
54 - Fuel pump circuit fault or Mixture Control (M/C)
solenoid fault or Electronic Control Module (ECM)
fault/EGR solenoid #2 failure (3.8L VIN1)
Fuel pump relay
75 - Digital EGR fault - #1 solenoid or system voltage low
(charging system problem)
Transmission voltage low
Any help would be very appreicated
Old 01-09-2010 | 07:20 PM
RUFFNECK4LYFE's Avatar
Looks like its all related to a fuel problem. Get a fuel pressure gauge hooked up to it and check your pressure at start up, rev'd, and when shut off. My guess, the fuel pump is on its way out. But thats only a guess.
Old 01-09-2010 | 11:44 PM
okay thank you ill try that, now i read somewhere how to do it but i cant find it, mine dosent have the schrader valve too hook up too so how would i do it in line?
one44magnum
11-09-2007 05:15 AM
grimreaper105
07-13-2006 12:11 AM
chevyfreak36
06-08-2006 02:40 AM
Polaris 500
01-25-2006 01:48 AM
judykevans
08-15-2005 06:51 PM
Quick Reply: 95 running problems
