98 chevy-have to turn ignition on 3 times to get fuel to engine.
Old 10-17-2011 | 09:19 PM
zuicey227's Avatar
Default 98 chevy-have to turn ignition on 3 times to get fuel to engine.
98 chevy suburban 5.7 4 by 4
just wondering if my fuel pump is going, i can hear it on and i have pressure up to 58psi. In the morning i have to turn the ignition on 3 times to get fuel to the engine, i think it drains back. any one have any ideas.
Old 10-18-2011 | 06:04 AM
RUFFNECK4LYFE's Avatar
Is that 58 psi with first key on? Does is stay at 58 or drop off?
Old 10-18-2011 | 06:48 AM
You will get more responses if you start your own thread so I have moved it.
Old 10-21-2011 | 12:44 PM
zuicey227's Avatar
i don't crank the engine, but i turn the ignition till i hear the fuel pump turn on and then i turn it off , then i do it again about 3-4 times, then crank it and it starts, if i don't it would be just cranking it 4-5 times to get it started. i checked the pressure and it holds a couple of hours if it sits to long(afternoon) i have to do it all over again.
Old 10-21-2011 | 01:20 PM
NullHead's Avatar
Mine does the same thing ... I just attributed it to the facts that: 1) my truck is ancient (1989), 2), the fuel pump in mine has a "self bleed off" that, from what I understand is supposed to do this, and 3) my truck only needs roughly 13 psi anyways, so no use in even trying to keep that little fuel pressure pressurized.
Sounds like the pump is bleeding down. Unfortunately you need a new pump to resolve it.
Old 10-22-2011 | 06:19 PM
zuicey227's Avatar
thanks i guess i will get a new pump. where ever i can get a cheap one.
Old 10-26-2011 | 10:02 PM
Ebay! Just replace the fuel pump only and not the whole harness. They are bout $50.
bradyjames
07-07-2010 08:56 AM
bradyjames
07-03-2010 01:23 AM
x3no
03-07-2008 10:20 PM
72charger
21
09-11-2007 08:08 AM
MrLM7
08-13-2007 10:08 AM
Quick Reply: 98 chevy-have to turn ignition on 3 times to get fuel to engine.
