ABS and Brake light
Old 01-23-2009 | 01:45 PM
ahcapone's Avatar
Default ABS and Brake light
For about 6 months my ABS and Brake lights have been coming on togehter and random times. It's been doing it more often this week after a trip through the desert. I take the truck to the beach about 4 time a year, don't know if this would have anything to do with it. I replaced all pads and rotors 3 months ago. Besides that, I don't what else to check, any suggestions? Thanks in advance.
Old 01-23-2009 | 01:50 PM
bfg112's Avatar
Default RE: ABS and Brake light
Try cleaning the wheel speed sensors. That can trip the ABS light, and cause your ABS to kick in when it shouldn't at low speed. I've heard stories of people putting their trucks through their garage doors because the ABS tripped trying to stop in their driveway.
Old 01-23-2009 | 02:10 PM
ahcapone's Avatar
Will do. Do you know if there is a free repair manual online somewhere? I have tha Haynes, useless.
Old 01-23-2009 | 03:04 PM
bfg112's Avatar
I'm not sure if theres a free one or not. If there is I'd like to see it.
Old 01-23-2009 | 07:18 PM
tylerz71's Avatar
ORIGINAL: bfg112
Happened to me.
damn GM brakes.
I pulled my ABS fuse and all has been well since. best free mod you can do if the ABS is giving you ANY trouble. I wouldnt suggest running it without ABS on ice unless you are a decent driver, unlike most of the people these trucks seem to be dumbed down for.
and yes when I pulled my fuse the ABS and BRAKE light indicators came on. but I got used to it.
the wheel speed sensor is behind the hub. most trucks affected with the abs problem are from up north due to the corrosion. the sensors will read incorrectly and lock the ABS in when it isnt needed. there is a good chance you will need to buy hubs too. about $300-400 for the parts from Napa. I think. I didnt feel like messin with any sensors so I pulled the fuse.
Old 01-24-2009 | 11:40 AM
chrisbmo2000's Avatar
A VSS will also trip the abs and brake light.......how about the brakes them selves??????? do they still have "life" left?
Old 01-26-2009 | 10:36 AM
ahcapone's Avatar
The brake pads and rotors are all new, >3months old. I'll check the vss and the wheel speed sensors, hopefully I don't need new hubs. I don't want to disable the ABS.
Old 01-27-2009 | 11:07 PM
rxsteven's Avatar
Check you dealer for any recalls. Just call them and give them your vin#. I did and they replaced me speed sensors and the tailgate cables.
Old 11-21-2011 | 01:13 PM
tukn20s's Avatar
what can you use to clean the speed sensors..i have this problem and would like to clean them.
thanks
mic_in_chevy
13
08-14-2014 07:45 PM
05chevytruckguy
02-15-2012 10:58 PM
GMCSierraFan
04-25-2011 05:38 PM
08limited2148
04-13-2010 05:07 AM
dharsen
01-25-2008 01:54 PM
